1991 Geo Prizm alternator
1991 GEO PRIZM
165,000 MILES • 4 CYL • FWD • AUTOMATIC
MONSTERMAN4
I have replaced the alternator several times in this car. Is their a cure for this problem or is this just a bad design problem.
Feb 2, 2008 at 2:19 PM
MMPRINCE4000
  • 8,548 POSTS
Could be the replacements are bad. The original alternator is a good unit.
Could also be there that one of the rock shields is missing allowing water to get to the alternator, or you have a bad ground wire somewhere, or there is an exhaust leak blowing hot exhaust on the alternator, or the wiring to the alternator is frayed and intermittently grounding, etc. etc.
I have two Prizms, 136,000 and 145,000.... both with the original alternators.
Feb 4, 2008 at 6:23 AM
