1990 Geo Prizm Tranny removal
DON ALCORN
Transmission problem
1990 Geo Prizm 4 cyl Front Wheel Drive Automatic
Does the tranny come out the top or the bottom?
Mar 12, 2009 at 8:31 AM
MMPRINCE4000
  • 8,548 POSTS
Out the bottom if you are just removing the tranny.
Out the top is removing both engine and tranny.
If working in garage with cherry picker, it is easier (for me) to take the whole works out the top.
With engine and tranny out, you can very easily change WP, timing belt and any seals (rear main) that should be changed.
MAKE SURE you refill transmission differential fluid when you re-install.
Mar 13, 2009 at 12:08 AM
