1990 Geo Prizm car smokes on start up
1990 GEO PRIZM
CARPETMAN1759
  • 81 POSTS
Engine Mechanical problem
1990 Geo Prizm 4 cyl Front Wheel Drive Automatic
Car will smoke on start up every once in a while.But does not use a drop of oil.Has 110,000 miles on it and runs great.I think it is the valve seals.How can I do this?Do I need to pull the head?
Oct 31, 2010 at 3:03 PM
MMPRINCE4000
  • 8,548 POSTS
No you do not have to remove head, but you need compressed air and a special tool set to change seals.
The valve springs are recessed in head, kit includes fixture that mounts on three valve cover studs and valve spring compressor.
It is a Kent-Moore tool, and is hard to find, try ebay.
If you cannot find one, then you will have to remove head.
Nov 3, 2010 at 12:32 AM
