1997 Geo Metro Water Pump Bad? But not leaking
1997 GEO METRO
157,426 MILES • 4 CYL • FWD • AUTOMATIC
CONNIEB
Hi my name is Connie Bustamante, and I have a problem.
I drive a 1997 Geo Metro 4Cyl. Automatic. I have owned this vehicle for about 8 yrs. My problem is that my temperature gauge gets really high and actually overheated last week. I have had this problem for about 2 months now. I do not have a leak but could not figure out why the temp. gauge would get high. I checked to see if the fan worked. It works, thinking it might be the radiator I checked for a leak. No leak it holds the coolant fluid. Thinking it was the thermostat I changed it and still no luck. So then I figured it must be the temperature sensor. And still no luck in fixing the problem. So then I changed the hose on the bottom hose that connects to the radiator. Still gets hot, I took it to a shop thinking maybe it needs a coolant flush. However they decided to do a diagnostic check instead and $100 later they told me what I already knew. The fan, radiator, thermostat, temp. sensor, radiator cap and hose is fine. They said everything was circulating okay. But it may be the water pump. I had the water pump, radiator and timing belt replaced 4 yrs. ago. My water pump has no leak and seems to be in good condition. Could it be the water pump if it is not leaking and still looks good? I can not for the life of me figure out what is wrong with my car. Do you have any suggestions as to what could be wrong.
Sep 13, 2008 at 5:15 PM
BLACKOP555
  • 10,386 POSTS
try a full cooling system flush.
next with the water pump, lots of them fail without even leaking, the impellers inside can corrode right off.
to let you know a lean fuel mixture can cause overheating so can a faulty head gasket.
Sep 14, 2008 at 9:37 AM
