1997 Geo Metro turning signals
135,000 MILES • 4 CYL • FWD • AUTOMATIC
RICHARD7000
More information on issue: The hazard lights work front and rear and the lights flash inside the car. But I have no turning signal front or rear and no turning signal lights inside the car. I have already changed the flasher.
Feb 28, 2010 at 11:48 AM
BLUELIGHTNIN6
  • 16,542 POSTS
check the fuse for the signals. if OK and flasher is good too then check wiring. if wiring OK then suspect faulty signal switch
Feb 28, 2010 at 12:42 PM
