Stalls at idle
200,000 MILES • 4 CYL • FWD • AUTOMATIC
NOPLAINJANE
Hi
We have a 97 Geo Metro with a 4 cylinder. Recently we began having problems with it staying running until eventually it would not even start at all. A friend suggested we replace the throttle positioning sensor, which made sense, so we did.
Now it starts, no problem, unfortunately, the throttle is stuck WIDE open and will not throttle down. We tried resetting the computer but that did not help. We cannot leave it running long enough to mess with it for fear it will blow up and dont really have a clue as to where to start.
Does anyone have any suggestions? With fuel prices approaching $4 a gallon in Washington state, it would be so nice to have the Geo running again.
Thank you in advance.
Janie
May 2, 2008 at 10:15 AM
  • 75,988 POSTS
Try below
Too fast an idle speed. If an engine without computerized idle speed control is idling too fast and refuses to come down I would service the throttle bore and IAC
Here are guides to help
and
https://www.2carpros.com/articles/how-to-replace-an-idle-speed-control-motor-iac
Here is a guide that can help as well.
https://www.2carpros.com/articles/stall-at-idle
Please run down these guides and report back
Cheers
May 2, 2008 at 10:29 AM
TNJ8361
Have a question regarding something similar. Dealership told me the CE light was on due to throttle body I think. Said that throttle may be getting stuck at times I think. Whichever was I do know that it would lower gas mileage. No problems with my rpms or anything like that usually stays between 1 and 2 till get on it quick. So I did what you said and serviced the throttle bore and IAC and the car has never run better thanks so much.
May 25, 2016 at 8:04 PM
JIMHARTY63
Engine Mechanical problem
1992 Geo Metro Front Wheel Drive 50000 miles
Example: If I run idle up to 2500rpm once it reaches it she wants to die then revs back up to 2500rpm and wants to die again. it will go up and down up and down no matter want rpm you try to hold steady PLEASE HELP I AM LOST...
Aug 5, 2018 at 1:51 PM (Merged)
  • 75,988 POSTS
Check the fuel pressure to rule out the fuel filter, fuel pressure regulator and fuel pump and test the throttle positon sensor and manifold absolute pressure sensor.
