1997 Geo Metro One dim headlight
140,000 MILES • 4 CYL • FWD • AUTOMATIC
MFARINA
On my 97 Geo Metro the passenger side headlight is dim.
I have switched the bulbs from side to side and the problem stays on the passenger side. It also stays dim with the high beam on. I have checked the voltage and it is getting voltage to the plug but it is getting voltage on 2 of the 3 terminals at the same time. I checked the ground and it is good. Can you help me figure out what the problem may be. Thanks.
Feb 5, 2009 at 7:25 AM
DOCFIXIT
  • 18,828 POSTS
Most likely the ground find black wire follow to body see if clean and tight.
Feb 10, 2009 at 7:04 AM
