1997 Geo Metro inner tide rod end
1997 GEO METRO
ZEANGRANT
Shakes or Wobbles problem
1997 Geo Metro 4 cyl Automatic
How do I replace an inner tide rod end
Oct 29, 2010 at 11:36 AM
BLUELIGHTNIN6
  • 16,542 POSTS
Raise and support the vehicle on jack stands. Remove the wheel using the ½-inch air gun and socket. Remove the cotter pin in the outer tie rod stud using the wire cutters. Remove the outer tie rod nut with a wrench.
Loosen the lock nut on the outer tie rod shaft using a wrench. Remove the tie rod from the spindle by placing the forked end of the tie rod separator tool in between the spindle and the tie rod. Hit the tool with the hammer until the outer tie rod comes loose in its tapered hole in the spindle. Lift the tie rod out of spindle.
Turn the outer tie rod counterclockwise to remove from the shaft. Count the number of turns it takes to remove it from the shaft, as this will be important in installation. Make a note of the turns. The tie rod end will need to be installed on the new shaft the same number of turns for alignment purposes.
Remove the inner tie rod end boot by using the wire cutters and twisting and cutting the clamp holding it in place. Pull the boot off the shaft. Insert the proper-sized end of the inner tie rod remover into the tie rod remover tool. Use the inner tie rod remover to screw the inner tie rod off the rack.
Install the new inner tie rod by screwing it on the rack by hand as far as possible. Using the inner tie rod remover tool, turn the inner tie rod end clockwise until tight.
Push the inner tie rod boot on and place the large clamp around the inner part of the boot where it fits unto the rack. Use the wire cutters to pinch the end of the clamp to hold in place.
Run the lock nut on the tie rod shaft and screw it up to above the middle of the thread. Screw the outer tie rod on for the number of turns recorded when removed. Insert the tie rod into the hole in the spindle. Screw the nut on and tighten with a wrench. Install the cotter pin and tighten the lock nut against the outer tie rod end with a wrench.
Install the wheel with the ½-inch air gun and socket.
Oct 29, 2010 at 11:40 AM
