1997 Geo Metro Engine stall at normal operating temp
87,000 MILES • 4 CYL • 2WD • AUTOMATIC
WILL SOLOMON
The car will idle until the tank runs dry. While driving the vehicle reaches normal operating temperature and then stalls out. After about 30 to 40 seconds the car will start again and run for about 1/2 mile then once again stalls out. I have had all the elec components checked or replaced and still the problem exists.!!!!!! Can you steer me toward a solution?
Mar 1, 2010 at 8:03 AM
DJCARSON
  • 10 POSTS
My car would not start after i drove for awhile. i would have to wait a little while and then restart. after a while it got worse and would die on me while driving. turned out to be a bad fuel injector. easy replacement and the problem stopped and never came back. hope this helps
and good luch
Jun 18, 2010 at 3:05 PM
