1997 Geo Metro 97 GEO METRO
JOHN SMITTERS
Electrical problem
1997 Geo Metro 4 cyl Front Wheel Drive Automatic
DRIVING NORMAL ENGINE WILL STOP RUNNING, SOMETIMES IT WILL RESTART. LET CAR SIT FOR AWHILE THEN IT WILL START. FUEL PUMP IS OK
May 12, 2008 at 6:09 AM
BMRFIXIT
  • 19,053 POSTS
check for spark
Check crank sensor near crankshaft pulley
May 18, 2008 at 11:09 PM
DJCARSON
  • 10 POSTS
my same issue turned out to be the fuel injector. easy replacement. also, the fuel injector wire harness had a recall. if thats a problem, you can wiggle it around until you get the correct ohm reading from the haynes manual for a quick fix. But the problem your having was the fuel injector in my case.
Jun 18, 2010 at 4:18 PM
