1996 Geo Metro wont start
1,000 MILES • 4 CYL • FWD • AUTOMATIC
MONT BALL
This car with a rebuilt motor of about 1,000 miles
was running down the road at about 55 mph when it died , after towing it home I checked if it had spark , then fuel ... I replaced the injector,in the throttlebody I then replaced the fuel pump relay in the fuse box area under the hood ,I can pour fuel down the throat and it will run until its out of fuel, then I replaced the fuel pump ,then the crank sensor even though I did not feel that was it , then the ecm, and today changed out the throttle body completly ,It still runs when fuel is poured down the throat of it but The injector does not put any fuel out is there another sensor or fuse Im overlooking ?? I,M so frustrated with this thing after about replacing everything I can imagine to be a problem...Thanks Mont
Mar 6, 2008 at 9:32 AM
RMCCABE36
  • 9 POSTS
What about replacing the fuel filters or possibly checking for a clog in the fuel lines.
May 20, 2008 at 8:35 AM
