1996 Geo Metro massive leak, complete failure
10,400 MILES • 4 CYL • 2WD • AUTOMATIC
CHRIS0404
first my speedometer suddenly stopped working. I removed the cable.
Next, driving a short distance a loud clunking noise occurred with a massive transmission leak.
I babied the car 5 miles back and parked. I added a quart of transmission fluid and it poured straight through. upon examination of the transmission case I discovered 3 chunks had blown out midway up the housing close to
where the two halves of the case bolt together.
To move the car a few feet can I used some type of special epoxy to slow down this massive leak?
also exactly what went wrong so quickly and massive with the tranny. I have a feeling there is loose chunk or a gear chugging internal in the case.
Finally it sounds to me like this old car is now a charitable gift.
The repairs would probably cost more than the car's
value by a large sum! Could I be wrong.
i would appreciate some serious advice and help from someone who is a true transmission specialist. i'm williing to pay for knowledgeable advice from a transmission specialist.
Aug 31, 2008 at 8:28 AM
  • 31,937 POSTS
Hi there,
Thank you for the donation,
You have suffered a major internal failure , possibly a diff gear has shattered and the shrapnel had smashed the case, you can try and plug up the case, but i feel the internal damage will be terminal, the cost of repair will be high as the cars is destroyed, your cheapest option will be a transmission from the wreckers.
Mark (mhpautos)
Aug 31, 2008 at 10:36 AM
