1996 Geo Metro Head Lights
HILDACECILIA
Other Category problem
1996 Geo Metro 4 cyl Wheel Drive Type unknown Automatic 155000 miles
I seem to have a problem with my head lights - they will not come on, parking lights are fine, tails lights, dash lights, the only way to get the lights to stay on is to hold the things towards me while I am driving and that only turned on the high beams.
I had some work done recently, the timing chaing replaced as well as a pulley and the fuel filters and fuel pump but this started before then.
Dec 3, 2007 at 8:00 AM
GFIMOTORCARS
  • 673 POSTS
This could be as simple as a fuse or even a cut wire. Check the fuse box for good fuses. If the fuses are good I would check all wiring to the headlamps.
Feb 27, 2009 at 11:12 AM
