1996 Geo Metro door hardware problem.
120,000 MILES • 4 CYL • FWD • AUTOMATIC
CHRIS1284
The window has fallen out of the track of the door
regulator. The car was sold to my wife with the driver font door handle removed.
I removed, lubricated and replaced the door regulator. It works fine. The problem is the window does not stay in the track. I know very little about how a regulator works. I assume the track silides along the bottom of the window as it is raised or lowered. THERE IS NOT A RUBBER GASKET IN THE
GLASS TRACK OF THE REGULATOR OR ON THE BOTTOM OF THE WINDOW ITSELF.
Any advice you can provide is greatly appreciated.
Feb 16, 2008 at 7:41 AM
2CARPRO JACK
  • 11,533 POSTS
The plastic rollers can sometimes wear out to the point where they fall out of the track. GO to dealer and get new rollers, should fix the problem. Will th eglass move freely up and down in the door by hand? be sure nothing is causing it to pop out
Feb 17, 2008 at 12:32 AM
