1995 Geo Metro Turn Signal Blows Fuse
1995 GEO METRO
130,000 MILES • 4 CYL • 2WD • MANUAL
RBAGGERLY
The turn signal fuse blows when I use it. I originally thought that there may be a short in the wiring to the bulbs but the Emergency Flashers work without a problem so I don't think that's it. The only thing I can think of is the switch in the column. Is there anything else it could be?
Feb 8, 2010 at 12:30 AM
BLUELIGHTNIN6
  • 16,542 POSTS
if the wiring to the switch is OK then most likely it is a faulty signal switch
Feb 28, 2010 at 12:55 PM
