1995 Geo Metro Radiator fan problem
MAGIC.SEAN
Electrical problem
1995 Geo Metro
My radiator fan does not seem to be working right, as it does not start spinning when I start my engine.
The radiator fan will rotate when connected directly to the battery or when I disconnect the fan switch.
I saw an answer to a similar question which said to check for a faulty radiator cap, but the cap feels like it is snug and secure, so I followed the hose leading from the cap and it is connected to the coolant resevior, however the resevior is cracked near the top above the fill line (from a recent accident I assume).
Nov 21, 2008 at 10:49 AM
  • 75,988 POSTS
Check the fan relay, coolant temperature sensor and also the computer control of the relay.
Nov 21, 2008 at 11:16 AM
MAGIC.SEAN
Thanks for the quick turn-around for the answer!
I checked the fan relay by switching it with like spec'ed relays for other features (Lights 1 and Lights 2) and the lights and fan behavior is consistant no matter which relay is placed where.
The fan switch i disconnected is located at the end of the radiator hose where it enter the engine (unser the distributor), I think that is the coolant temp switch, is that the same as the sensor? Anyway, when I disconnect it the fan starts right up.
I haven't come across any relay computer control for the Geo Metro 3 cyl. but I willl do some research in that direction.
Nov 21, 2008 at 11:46 AM
