1995 Geo Metro Oil leak
1995 GEO METRO
PEFIN1977
Other Category problem
1995 Geo Metro 4 cyl Wheel Drive Type unknown Automatic 130000 miles
I have a small oil leak under the power steering area that cannot be located. I have changed my timing belt, water pump, oil pan, and various hoses and belts, but there are still two small drops of oil after I drive the car. Any ideas what might be the cause?
Feb 5, 2008 at 5:23 AM
NDDUNC01
  • 18 POSTS
YES,IHAVE AN ANSWER,I HATE TO BE SO BLUNT BUT YOUR PUMP HAS A SEAL OUT! GO TO JEFFRIES AUTO SALVAGE.COM &THEY WILL FIX YOU UP[IF THEY CANT THEN THEYLL PUT YOU ON THE RIGHT TRACK] KEEP IN TOUCH!!!
Feb 8, 2008 at 4:50 PM
