1995 Geo Metro Engine Coolant
1995 GEO METRO
120,000 MILES • 4 CYL • 2WD • AUTOMATIC
SUZETTEHUTT1
There is engine coolant coming out of the engine block and onto the firewall. Any idea what is causing this? Also can it be repaired?
Thank you,
Mar 8, 2010 at 2:33 AM
BLUELIGHTNIN6
  • 16,542 POSTS
Check for cracked freeze plugs. If that's not it, may be cracked head or block. To find this out, would have to do cylinder compression check.
Apr 22, 2010 at 1:50 PM
