1994 Geo Metro 1994 3cyl Geo Metro 1.0L Manual transm blowi
173,000 MILES • 4 CYL • FWD • MANUAL
ALINA_LESYA33
I own a 1994 GEO Metro man. transm. 1.o l engine. The other day was driving on the highway and the car shut off. Tried to start back up - sounds like the engine wants to crank over but never actually does. Found a blown FI(fuel injector) fuse. Replaced the fuse and jumped the car - car would not start and blew the fi fuse. Then tried just replacing the fuse and not jumping the car - still will not start and blows the fuse again.
Came home and replaced the fuel injector relay. Still nothing and blown fi fuse. Then replaced the throttle body injector - still no start and keeps blowing the same fuse.
Any idea what I should do next? Had someone recommend replacing the ecm (engine control module) but I wanted to see if any one would be able to help me with advice before I spent money on something that doesn't fix the issue.
Thanks ahead of time.
May 24, 2010 at 1:15 PM
DOCFIXIT
  • 18,828 POSTS
That fuse powers fuel pump remove fuel pump relay see if fuse holds
May 25, 2010 at 4:55 AM
