1992 Geo Metro Dead battery
14,000 MILES • 4 CYL • FWD • MANUAL
JDFREEJ
Hello!
My Metro would not start due to a dead battery.After charging the batt. it would start fine, untill it would sit overnight, then batt. dead again. The battery was old and I figured time to replace. Well I put a new batt. in it. The car set overnight. Battery dead. What next???
THANKS!
Nov 27, 2008 at 3:16 AM
  • 31,937 POSTS
Hi there,
You will need to get a current draw test done, as something is staying on and draining the battery, start here.
mark (mhpautos)
Nov 27, 2008 at 3:06 PM
CHALLENGERBOY
  • 13 POSTS
Did you check your altenator?
Jan 12, 2009 at 8:05 AM
GUSJDJ
Had the same problem..took out the altenator had it checked...it's fine..come to find out ..the belt was never tight enough..even though it LOOKS like everythings rotating ok..Get a new belt and make sure it's TIGHT!. My altenator was never spining fast enough for proper output to the battery.
Jay
Mar 20, 2011 at 9:48 AM
