I have A 1989 Geo Metro the headlights will no longer work, They will flash on when you pull back on the dimmer switch, The bulbs are good, the headlight switch is also good, The 3 wires that go to the headlight bulbs are all hot,Even with the switch off, I thought the center wire was the ground, When I ran A ground wire to the center wire they came on even with the switch off, Is there any relays on this? All fuse's are good
could the dimmer switch be bad? & if it is how can I test it.
Please help.
Alan
Please help.
Alan
Sep 25, 2008 at 4:43 PM
