Starter makes a noise when starting
69,000 MILES • 4 CYL • TURBO • 2WD • AUTOMATIC
BRYANGENESIS2.0
The car listed above is a coupe 2.0T. It was running perfect all day until the afternoon when I went to the store I had my windows down and put the car to park but forgot my windows were down. so I turned the car back on right away to close them and when I tried to turn it on the car made a loud starching sound more like metal was hitting together or something. I can’t really explain how it was so I left it off for a minute and tried again and the car turned back on but now it’s making that sound every time it try’s to start up. Runs perfect after the sound goes away and starts up.
Aug 10, 2020 at 3:55 PM
  • 110,251 POSTS
It sounds like the Bendix on the starter isn't fully engaging the starter drive gear and flywheel. Can you do me a favor? Record the sound and upload it for me to hear. I should be able to tell if that is the problem.
Aug 10, 2020 at 4:24 PM
BRYANGENESIS2.0
Does this help?i don’t have the car with me right now I left it parked where it was until I found out what it was. I don’t want to damage anything else. the last thing I ever did was change my belt on it after it snapped about a week ago.
Aug 10, 2020 at 4:31 PM
  • 110,251 POSTS
Either the starter Bendix is bad and not fully engaging to start the engine, you have a couple teeth off it, or the starter is loose. Make sure it is tight and doesn't move around by hand.
You need to remove the starter and inspect. If nothing on the flywheel is damaged, replace the starter. Actually, you can have it bench tested at a parts store.
Here is a link that explains how in general a starter is replaced:
Here are directions specific to your vehicle. The attached pics correlate with the directions.
______________________
2013 Hyundai Genesis Coupe L4-2.0L Turbo
Repair Procedures
Vehicle Starting and Charging Starting System Starter Motor Service and Repair Removal and Replacement Repair Procedures
REPAIR PROCEDURES
Removal and Installation
1. Disconnect the battery negative cable(A).
pic 1
2. Set the jack under the engine oil pan.
NOTE:
Insert the rubber block between engine oil pan and jack to prevent the damage of oil pan.
3. Remove the LH engine mounting bracket nut (A).
Tightening torque :
63.7 - 83.4 N.m (6.5 - 8.5 kgf.m, 47.0 - 61.5 lb-ft)
pic 2
4. Lift up the engine assembly slightly by using a jack to get access to the side of engine.
5. Remove the engine support bracket (A). And then remove cable and connector from starter (B).
Tightening torque :
49.0 - 63.7 N.m (5.0 - 6.5 kgf.m, 36.2 - 47.0 lb-ft)
pic 3
6. Remove the bolts and starter (A).
Tightening torque :
42.1 - 53.9 N.m (4.3 - 5.5 kgf.m, 31.1 - 39.7 lb-ft)
pic 4
7. Installation is the reverse of removal.
_____________________________
Aug 11, 2020 at 8:48 AM
