When pulling away while turning the vehicle shutters?
185,000 MILES • V8 • 4WD • AUTOMATIC
UPMM019
  • 217 POSTS
So, I'm not sure if that is a suspension or drivetrain or transmission issue, intermittently? I bought the vehicle listed above LTZ used last October and so far, it has been a good vehicle. I had to replace all of the shocks and pump as well as the A/C condenser.
I do not know the history so curious to know what items I should have serviced to help prevent any issues or just good maintenance for high mileage?
The only concern I have is sometimes pulling away while turning the vehicle shutters so I'm not sure if that is a suspension or drivetrain or transmission issue. It's intermittent and I cannot reproduce it over and over.
Sep 9, 2022 at 1:12 AM
  • 110,248 POSTS
It could be a few different things. Have you checked the transmission fluid to make sure it is clean and full?
https://www.2carpros.com/articles/how-to-check-and-add-transmission-fluid
Also, when you notice this happening, is there any noise or sounds associated with it? For example, do you hear clicking?
Sep 9, 2022 at 2:20 PM
