Engine keeps shutting off
101,000 MILES • 2.0L • 4 CYL • TURBO • 4WD • MANUAL
IFRANCO55
Hello, I have the car listed above which keeps shutting off on me after a few seconds of being on. Any tips on how to diagnose this issue? Could it be fuel cut related?
Feb 28, 2022 at 10:32 AM
There are a number of things this could be, but we need to start by checking the fuel pressure when this is happening.
Here is a guide that will help with checking the pressure:
Once we know what the pressure is doing when this happens, we can make a better decision.
However, there are a couple other things that we need to check as well. This would be if the theft system remained active.
If the engine starts and stalls, then this would be a theft issue as well.
https://www.2carpros.com/articles/how-to-reset-a-security-system
The last thing that would make sense is an idle air control valve.
I would suggest replacing it but here are a couple guides for this as well as I am attaching the info below on how to test it:
https://www.2carpros.com/articles/idle-air-control-valve-service
https://www.2carpros.com/articles/how-to-replace-an-idle-speed-control-motor-iac
Please run through this info and let us know what you find. Thanks
Mar 1, 2022 at 10:09 AM
