Gear shift
2003 ACURA TL
126,494 MILES • AUTOMATIC
DJMARIE
  • 21 POSTS
I am unable to shift from park. I was able to bypass the gear shifter by pressing the release button to move it into neutral ( with emergency brake on).
Then starting the car. What cause and and is this an expensive fix?
Thank you,
DJ
Mar 23, 2018 at 7:19 AM
KHLOW2008
  • 41,814 POSTS
A blown fuse can cause this. check the operations of the brake lights and if they are not working, check for a blown fuse. The other possible cause would be a faulty brake switch or interlock solenoid under the console. Cost of repairing would depend on what is wrong.
Mar 24, 2018 at 1:34 AM
