Gears not working after replacing radiator.
73,163 MILES
FRANCKAF
Car was taken to the mechanic to replace leaking radiator. After repairs and drinving for about 3 minutes, car stopped. Gears were not catching in either forward or reverse. Mechanic says the gearbox already had a problem and the problem was already there. Specific model is a Rio LS, 2003
Can describe exactly how and why this happened?
Jun 6, 2013 at 7:21 AM
HMAC300
  • 48,601 POSTS
is it an automatic or manual, check fluid first anyhow it may be low causing your problem.
Jun 6, 2013 at 8:36 AM
  • 55,743 POSTS
Hello, I would check the electrical connector on the transmission, it sounds like they bumped it off or messed with the wiring somehow. Also check the tranmission fluid level, if they added fluid it needs to be OEM fluid or it can casue a malfunction. Is the check engine light on now? Please get back to us, we want to help you solve this problem.
Jun 6, 2013 at 9:12 AM
FRANCKAF
What is the worst that can happen in situation like this. Is so, can it be repaired or I have to purchase a new one?
Jun 7, 2013 at 2:46 AM
HMAC300
  • 48,601 POSTS
any transmission can be repaired most of the time unless hard parts like a case is bad then you need another case. But has the radiator leaked water into transmission? if it is di yo have to stop or make sure that the new radiator isn't doing the same otherwise you 'll have same problem.
Jun 7, 2013 at 2:56 AM
  • 55,743 POSTS
Has the transmission fluid level been checked? also check the color of the fluid, if its a mikly pink the cooler failed in your last or pressent radiator. please respond
Jun 7, 2013 at 3:32 AM
