gears/clutch clutch pedal go down without me pressing?
117,000 MILES • 1.2L • MANUAL
KOTUK
while i have been driving i had 1 issue with my clutch to where without me pressing down on it while coming up to a junction i had felt the clutch pedal go down without me pressing down on it and a few times now i have had a problem to where it would refuse to go into gear
Sep 7, 2026 at 9:44 PM
What to check next
Diagnostic guidance. Suggested checks and possible repairs are separate from the owner's reported results.
Arrange inspection before further driving with unreliable clutch operation, and do not force the gear lever. Start with the pedal and actuation mechanism. If this version uses hydraulics, inspect the specified fluid reservoir, lines, master cylinder and slave cylinder for leakage and proper operation. A sinking pedal can involve hydraulic pressure loss or a mechanical actuation problem; it does not identify the slave cylinder by itself. Ask the garage to explain which test or leak demonstrates the failed part. If the system shares brake fluid and the level is low or braking is abnormal, do not drive it. Request an itemized estimate after identifying whether the slave cylinder is external or inside the bellhousing. An internal unit can require transmission removal. Correcting the verified actuation fault may restore gear selection without replacing the entire transmission.
Guidance references and applicability
ZF Aftermarket: Clutch does not disengage https://aftermarket.zf.com/en/aftermarket-portal/knowledge-hub/clutch-does-not-disengage/ Explains that release-system faults, including cables, hydraulics and pivot points, can prevent disengagement. The exact installed system and repair labor remain vehicle-specific.
Read the replies · Discussion summary and reported outcome
MECHTRIX
  • 583 POSTS
Its Most likely time to change the ckutch slave cylinder.. sounds like it blew out and is leaking internally or externally so time for a new one theyre pretty cheap and are usualually pretty easy to change good luck hope this helps
Sep 9, 2026 at 3:02 PM
KOTUK
thank you for your reply i was just wondering what would include in getting it replaced at a garage and how much it could cost just so i know as i am new driver and i dont know much about cars thank you
Sep 9, 2026 at 10:58 PM
MECHTRIX
  • 583 POSTS
All shop are a little different on prices also some mark up the price of parts alot others not so much some try to save you money and some charge way to much so"..its Depending on where you live the shop rates are a bit different in each area..id say call around to the shops nearest you and ask what there shop rate is and how much time they'd charge for that job and what the parts cost thats the best way ti figure out what it's gonna cost befor you evan get there ..good luck hope this helps
Sep 11, 2026 at 6:47 AM
Discussion summary
The owner reported the clutch pedal dropping unexpectedly and intermittent refusal to engage a gear. A contributor suggested the slave cylinder. The owner asked about garage costs, but the discussion did not establish the failed component or report a repair.
Reported outcome: No inspection findings, slave-cylinder replacement or restored gear selection were reported.
The discussion did not verify the actuation design or failed component. The suggested repair cannot be assumed inexpensive or accessible without transmission removal.
Read the original discussion
