After changing from AWD to 2WD it is not shifting properly?
2005 SATURN VUE
230,000 MILES • AUTOMATIC
KELLI1030
  • 8 POSTS
I was having issues with the AWD. I took out the drive shaft to change it to 2WD. Now when I try to put it I gear, they don't work.
Oct 28, 2023 at 2:18 AM
  • 110,236 POSTS
I believe the drive shaft is needed because when the vehicle is not slipping, the drive wheels are in the rear.
What problems were you having?
Oct 28, 2023 at 2:27 PM
KELLI1030
  • 8 POSTS
05 saturn vue AWD. Rear differential making noise, pulled rear drive shaft to make rear wheel drive, front drive tires will not engage, but transaxle is shifting because rear output is spinning.
Oct 31, 2023 at 1:38 AM
KELLI1030
  • 8 POSTS
Before I took the drive shaft out, I was changing a wheel bearing, then it started making a lot of grinding noise in the rear and it wouldn't move in any gear. Like the ads were trying to kick in but shouldn't. I tried taking abs fuses out but that didn't work, put them back in and unhooked the battery to reprogram. That didn't work. So thought I'd try taking the drive shaft out to make it 2wd. And now I'm here.
Oct 31, 2023 at 1:51 AM
  • 110,236 POSTS
Which wheel bearing was being replaced? Are you sure the axle is fully engaged?
Question. If you place the vehicle in park, does it lock in place or does it move as if it is in neutral?
Oct 31, 2023 at 11:33 AM
KELLI1030
  • 8 POSTS
Right front wheel bearing, yes the axle is fully engaged. And yes it moves as if it's in neutral.
Nov 1, 2023 at 2:01 AM
  • 110,236 POSTS
If the vehicle is moving as if it is in neutral while in park, the driveshaft needs to be present. The hydraulics in the trans won't support the removal of the driveshaft.
So, we need to focus on what the noise is being caused by. Is it possible for you to record and upload the sound so I can hear it?
Nov 2, 2023 at 5:52 AM
KELLI1030
  • 8 POSTS
It was moving as if in neutral before rear drive shaft was removed.
Nov 3, 2023 at 5:37 AM
  • 110,236 POSTS
If that is the case and the shift linkage is working properly, something has come apart. If you lift the vehicle and spin the wheels, are you able to hear any odd sounds?
Nov 3, 2023 at 2:05 PM
KELLI1030
  • 8 POSTS
No noises.
Nov 6, 2023 at 5:19 AM
  • 110,236 POSTS
If there are no noises, try reinstalling the rear driveshaft to see if it still makes noise. If it started making noise in the rear when you replaced the right front bearing, something is not together correctly. It just doesn't make sense. Based on the description, it sounds like an axle isn't fully seated. Are there any sounds when in drive or reverse and the engine is running? I suspect we are missing something simple.
Nov 6, 2023 at 9:44 AM
KELLI1030
  • 8 POSTS
No noise when it's in drive or reverse and it's just sitting. But when you actually move and drive. The noise sounds like something rotating and smacking on the bottom of the car. The more I accelerate the faster and louder it gets. But I've looked under it and can't see anything smacking.
Nov 6, 2023 at 11:17 PM
  • 110,236 POSTS
What you are describing sounds like either a universal joint or an axle joint. If you have a helper stand beside the vehicle while you hear this, can it be identified if it is from the front, middle, or rear of the vehicle?
Do you feel the clunking in the floor of the vehicle as if something is indeed hitting it?
Let me know.,
Nov 7, 2023 at 10:03 AM
KELLI1030
  • 8 POSTS
Sounds like middle or rear of the vehicle. We already checked both joints because we thought that as well and they're fine. And yes, it feels like something hitting the bottom of the car.
Nov 7, 2023 at 10:24 PM
  • 110,236 POSTS
Has anyone watched under the vehicle when you experienced the feeling of it being hit from under the vehicle? Have you inspected the trans/engine mounts.
I realize there is a good chance you had someone watch, but it isn't making sense that you hear and feel it, but there is nothing obvious under it causing the noise/banging.
Have you opened the hood to check if the engine is moving in its mounts when you try moving?
Let me know. I think I already asked, but if you could record the noise and upload it for me to hear, that would be helpful. If you can't, I understand.
Nov 8, 2023 at 9:28 AM
