Gears
2008 VAUXHALL CORSA
60,000 MILES • 1.2L • 3 CYL • 2WD • MANUAL
WILLPENNING1
May sound odd, but if I sit in my drive stick my clutch down without the engine on the gears are all so smooth and easy. As soon as I start properly driving for about five minutes my gear one is very hard to get into. When I change from second to first or any gear to first it is a straight up battle I have to jam it in and it makes a noise , I recently bought this car second hand so I have six months warranty on it would you recommend taking it back or feel it would be an easy fix?
Oct 29, 2018 at 9:26 AM
  • 110,240 POSTS
First, check and make sure the clutch fluid is full. Most of these vehicles have a hydraulic clutch which consist of a clutch master cylinder and a slave cylinder. If the fluid is low, basically you are not disengaging the transmission from the engine. It would be similar to shifting without a clutch.
If the fluid is full, I suspect it will be one of the aforementioned components. Take a look through this link. It discusses the parts I mentioned. Please note that the link shows fluid being added to the master cylinder. On many cars, there is a separate reservoir for the clutch fluid.
https://www.2carpros.com/articles/clutch-doesnt-work-sometimes-or-not-at-all
Oct 29, 2018 at 11:16 AM
