After rebuilding the engine transmission is not engaging in fifth gear and reverse
1998 ISUZU KB280
459,000 MILES • 2.8L • 4 CYL • TURBO • 2WD • MANUAL
BERN44
I recently had an engine overhaul, after putting everything together fifth gear and reverse gear are not engaging it's as if something is blocking. i never opened the gear box. what could be the problem?
Dec 12, 2021 at 1:19 AM
  • 110,244 POSTS
If this just started since the engine was reinstalled, my first suspect is the transmission shift linkage isn't either connected correctly, something is bent, or something has come apart.
Keep in mind, fifth gear and reverse are operating on the same shaft in the transmission, so check to see if the linkage is properly connected. This issue wouldn't have happened by installing the engine.
Also, this specific model isn't offered in the US, so I don't have pics or tech info for it. However, I'll try my best to help.
Dec 12, 2021 at 12:49 PM
BERN44
Thanks for getting back to me i really appreciate it.
Dec 13, 2021 at 4:12 AM
  • 110,244 POSTS
You are very welcome. I just hope I can help. Let me know what you find or if you have other questions.
Dec 13, 2021 at 6:35 AM
