I can only get reverse to work if it is put in between the reverse and neutral. All other gears are fine.
Feb 12, 2017 at 12:42 PM
STEVE W.
✓Experienced Mechanic
Sounds like the shift cable is a bit worn or the detent pin plate is worn. It is not a hard fix, but it does mean the gear position switch may need to be adjusted and that requires measuring the switch continuity as you move the switch.
Feb 12, 2017 at 4:41 PM
95HONDAWAGON
MEMBER
How can I do that sorry I learn as I go. I can send a pic of it.
Feb 24, 2017 at 7:24 AM
Hey 95HONDAWAGON,
I found these diagrams to help you get the cable replaced.
