Transmission issue
130,000 MILES • 3.5L • 6 CYL • AUTOMATIC
TBABY860
I was going down the road at 45 in fourth gear when RPM's shot to 3,500/4,000 like it was in first gear. So I stopped pour some fluid poured some in waited a bit. on way home kinda side the same but this time with loss of power.
Reader says it has to do with transmission.
Oct 16, 2019 at 11:51 AM
Can you give me the actual code that you are getting? This sounds like limp in mode which is meant to protect the transmission so it doesn't have a catastrophic failure but let's follow what code we have and go from there. Thanks
Oct 17, 2019 at 7:00 AM
