Intermittent gearbox not responding
3,000 MILES • 1.6L • 4 CYL • TURBO • 4WD • AUTOMATIC
ZABIBU2020
When engaging reverse gear doesn't respond work. Sometimes when it's cold it responds well. But when the system becomes hot It can backup. What could be the problem?
Feb 13, 2020 at 10:21 PM
  • 110,248 POSTS
First check the basics. Make sure the transmission fluid is clean and full. If it is, here is a link that explains how to retrieve diagnostic trouble codes. See if any are saved.
https://www.2carpros.com/articles/suzuki-code-retrieval-and-definitions-1986-1995
I have to be honest. This model isn't offered in the US, so my technical info is extremely limited. However, I'll try my best to help.
Let me know,
Feb 14, 2020 at 5:03 AM
ZABIBU2020
My problem is solved after following your advice. Thanks.
Feb 22, 2020 at 3:29 AM
  • 55,711 POSTS
Can I ask what the problem was?
Feb 22, 2020 at 3:30 AM
