Gearbox or clutch
80,000 MILES • 2.5L • 6 CYL • TURBO • RWD • MANUAL
MOOREY94
I was driving along and i lost ability to accelerate as i changed gear and could not get the car back into gear. i could smell something burning? Possibly smell if a clutch burning? I am unable to now get can into gear at all.
It seemed to not be boosting/accelerating as well as it usually does before it happened.
Would you be able to help tell if it would be the clutch or if it is the gearbox?
Car is also modified.
Thanks
Jun 25, 2017 at 6:28 PM
HMAC300
  • 48,601 POSTS
see if it will shift into gear with engine off then check to see if clutch is pushing in, you will need an assistant as it can be a hydraulic problem or clutch. if check clutch master. if you see it working and it shifts to different gears with engine off clutch is probably the culprit. Especially since you smelled burning.
Jun 25, 2017 at 11:52 PM
MOOREY94
It feals and sounds like its going into gear but im not sure if it is? As i can start the can woth it "in gear"
I noticed that the brakes are also hard when car is runninh not sure if that is due to sitting for abit or if that could be indicatiom of problem also.
Jun 29, 2017 at 6:40 PM
HMAC300
  • 48,601 POSTS
brakes will be hard as engine doesn't run so no vacuum for power. I think y o have aclutch/hydraulic problem like I said in first reply
Jun 29, 2017 at 11:09 PM
