gearbox input shaft bearing removal
80,000 MILES
BRABHAM52
I have a noisy input shaft bearing, (clutch pedal down quiet, pedal up noisy ) Once I have removed the gearbox and the input shaft cover tube, is there any way I could remove the shaft bearing without dismantling more of the gearbox? I know this is possible on some older inline gearboxes. Thanks.
Feb 11, 2020 at 6:34 AM
JOETECHPRO
  • 705 POSTS
Hey BRABHAM52,
Can you please let us know the engine you have in this vehicle?
Regards, Joe
Feb 11, 2020 at 7:57 AM
BRABHAM52
Thanks for your reply, my car's engine is a 1.4 petrol 4 cylinder, and the code is BUD. the gearbox itself is code O2T.
Feb 13, 2020 at 7:56 AM
JOETECHPRO
  • 705 POSTS
Hey BRABHAM52,
I do not have the repair instructions for this operation.
However, if you watch at around the 2 minute mark in the video in the link below you will see the bearings are pressed in from the inside of the gearbox casing.
https://www.youtube.com/watch?v=vsITAdEjFPY
As far as i can see this video covers the operation you will need to follow pretty well.
Hope this helps.
Regards, Joe
Feb 13, 2020 at 2:17 PM
