Gearbox controller module
2006 FORD GALAXIE
50,000 MILES • 2.0L • 4 CYL • 2WD • AUTOMATIC
EMMANUEL AKPOJIYOVWI
I bought a replacement gearbox controller module for my car listed above (Ghia petrol), after fixing and scanning it reports that it is not compatible with the ECM. probably because it was from a tdci engine. What do I do to make it compatible?
Feb 9, 2018 at 1:05 AM
You will need the correct controller. the part numbers need to be exactly the same then the flashing needs to be done to match your VIN number to the module.
Feb 9, 2018 at 1:59 AM
thanks Roy, part number is the same 7G9N-14C336-DB. Please advice on how to flash. thanks.
emma
Feb 9, 2018 at 2:55 AM
you will need a factory scan tool, access to the manufacturer web site and then need a communicator. It would be easier to just have someone with the equipment do it for you.
Feb 9, 2018 at 4:13 AM
