Transmission stuck in third gear
130,000 MILES • 2.3L • 4 CYL • AUTOMATIC
KENNYGFORLIFE
In the morning, the car engages well but after few minutes of driving it gets stuck at third gear. If parked and restarted, it will start from the third gear until allowed to cool down after many hours but the moment engine is hot, it gets stuck at the third gear.
Nov 3, 2019 at 2:27 PM
  • 110,248 POSTS
Hi:
It sounds like the system is going in to what is known as limp mode. The vehicle's computer will do this to protect itself in the event of a problem. Basically, it allows the driver to "limp" to a safe location.
Can you tell me if the check engine light is staying on when the engine is running? Have you checked for diagnostic trouble codes.
Nov 5, 2019 at 3:34 AM
  • 55,721 POSTS
This guide will help you get the codes:
This guide can help as well:
https://www.2carpros.com/articles/reduced-power-limp-mode
Nov 5, 2019 at 7:02 AM
