Gear slipping
2005 NISSAN PULSAR
244,000 MILES • 1.8L • 4 CYL • AUTOMATIC
GOODFELLA83
Hi, I was driving my car listed above ST model today and the car went into a lower gear and started revving out.
There was little power going to the wheels and then no power..
Mar 16, 2020 at 5:28 AM
Good morning,
Is the check engine light on?
Did you check the fluid level?
When was the last time you had the fluid changed in the transmission?
Mar 16, 2020 at 5:38 AM
GOODFELLA83
Check engine light not on fluids fine and color. Don't know why this is happening.
Mar 16, 2020 at 5:50 AM
Okay, I would start by changing the fluid since you have not indicated when it was last changed.
If there is no check engine light, it is not electrical, it is mechanical. This could be an internal issue if the transmission service does not resolve it.
Mar 16, 2020 at 5:54 AM
