gear slipping?
121,330 MILES • V6 • 2WD • AUTOMATIC
DJMARIE
  • 21 POSTS
after car is warmed up and driving notice that as it seems to shift gears that it slips as when accelerating. is this the transmission? or something else?
Thank you
May 20, 2016 at 4:34 AM
HMAC300
  • 48,601 POSTS
check the transmission fluid first. If it has a dipstick as it may not. if low it can cause this or do a transmission fluid change, but if dark brown or black fluid it is probably going to need a rebuild.
May 20, 2016 at 5:10 AM
