Sir,
I have a issue with transmission. When i start my car in morning it works fine but after driving nearly 35 to 40 minutes car stop shifting the gear and stuck in a gear in which it is. I tried to put neutral then again in D but still in same gear in which car stuck. I tried to stop and off it for five minutes then car stuck in first gear not changing to others. Also manual option not working. With all this problems there is no noise and no smell from the gear box. But when car cools down it again start working normally for 35 to 40 minutes. Kindly can you tell me is there a problem inside the gear box or it is a sensor issue?
Apr 11, 2019 at 4:04 AM
