Gear shifter cable installation
100,000 MILES • 4WD • AUTOMATIC
PORSHAANN
Previously the car would not go into park so we replaced the gear shifter cable and it went into park for a little bit, but now it will get stuck in drive or park sometimes. We keep adjusting the cable but once you start to drive it it either slips or get loose and then the car will be in drive but stuck in park. Do you have any advice as to how to correctly install the cable or reason why it would keep slipping by itself? the bolts are screwed tight as well
Sep 5, 2019 at 12:03 AM
  • 110,248 POSTS
Welcome to 2CarPros.
I will provide the directions for cable replacement. Look through it to see if there is anything you may have missed.
There are two different options on this vehicle based on engine size. You didn't indicate which engine you have so I will provide directions for both.
___________________________________
2.5L V6
2005 Jaguar X-Type (X400) V6-2.5L
Procedures
Vehicle Transmission and Drivetrain Automatic Transmission/Transaxle Shift Linkage Shift Cable Service and Repair Procedures
PROCEDURES
Selector Lever Cable and Bracket
Removal
1. NOTE: To move the gear selector lever, the ignition must be in the RUN position, with the foot brake pressed.
Move the gear selector lever to 'N' position.
pic 1
2. Remove the center console right-hand side trim panel.
pic 2
3. Release the gear selector cable locking pin.
pic 3
4. Remove the center console side retaining screw.
pic 4
5. Detach the gear selector cable from the J-gate.
pic 5
6. Disconnect the gear selector cable from the J-gate.
pic 6
7. Detach the gear selector cable grommet.
8. Raise and support the vehicle.
pic 7
9. Detach the exhaust heat shield.
pic 8
10. Remove the gear selector cable shield.
pic 9
11. Detach the gear selector cable bracket.
pic 10
12. Disconnect the gear selector cable.
pic 11
13. Remove the gear selector cable from the gearbox mounting bracket.
1. Pull out the locking pin.
2. Remove the gear selector cable from the gearbox mounting bracket.
14. Lower the vehicle.
pic 12
15. Remove the selector cable.
Installation
pic 13
1. To install, reverse the removal procedure.
Tighten to 10 Nm.
pic 14
2. Tighten to 10 Nm.
________________________________________________________________________________________
3.0L V6
2005 Jaguar X-Type (X400) V6-3.0L
Procedures
PROCEDURES
Removal
pic 15
pic 16
pic 17
pic 18
pic 19
pic 20
pic 21
pic 22
pic 23
pic 24
pic 25
pic 26
Installation
pic 27
Tighten to 10 Nm.
pic 28
Let me know if this helps or if you have other questions. You are leaving something loose that needs to be tightened is my first suspect, so take a look and confirm you did it as the directions indicate.
Sep 6, 2019 at 1:19 PM
