when I shift to reverse or drive engine will stop / shut off?
300 MILES • 3.0L • 4 CYL • 2WD • AUTOMATIC
ARNEL TERRADO
Hi there, it happens on my Toyota HiAce super custom van A/T when i shift to reverse or drive engine will stop / shut off..
Feb 9, 2023 at 7:36 PM
  • 55,743 POSTS
I have seen the torque converter clutch solenoid stick on causing the problem you are describing but to be sure can you upload a short video of what the van is doing?
Here is a guide that can help you:
https://www.2carpros.com/articles/stall-at-idle
I have also seen a dirty throttle body, or a vacuum leak cause the problem as well.
This guide is used when the engine is cold only:
Please go over these guides and report back.
Feb 10, 2023 at 2:33 AM
