gear ratio
167,000 MILES • 5.7L • V8 • 2WD • AUTOMATIC
JASONPYZO
  • 87 POSTS
I am rebuilding the rear end and was wondering what the draw backs would be if I replaced the 3.42 gears with 3.73. I noticed when I pull me trailer it has a hard time starting off, I do not tow everyday. but was just wondering if that would be wise or would it kill my gas mileage or any other unforeseen issues that I do not see? The reason I am rebuilding the rear end is getting ride of the open carrier and going to limited slip. I would appreciate any information, Thanks
Jun 22, 2016 at 3:38 AM
WRENCHTECH
  • 20,760 POSTS
It will give you a little more low end power but it will also surely put a big hit on your fuel mileage. It will also make your speedometer incorrect.
Jun 22, 2016 at 5:11 AM
JASONPYZO
  • 87 POSTS
ok cool, I appreciate that. I got one more question, the gears that are in it right now show little to no wear do you think I show put fresh gears in or would it be fine to use the original ones?
Jun 22, 2016 at 7:31 AM
WRENCHTECH
  • 20,760 POSTS
If they show no wear, they should be fine. They are not a high wear item.
Jun 22, 2016 at 7:36 AM
