Whenever I select any gear it goes reverse. what can I do to fix this?
Jan 5, 2020 at 3:44 AM
✓Experienced Mechanic
For some reason, I have no info on this vehicle. However, have you checked to make sure the shift levers on the transmission are moving? Have a helper shift through the gears while you watch them. It sounds like a linkage issue between the shifter and the transmission.
