Transmission shifting problem
315,221 MILES • 4 CYL • 2WD • AUTOMATIC
SHAHBAZ MALIK
My car gear shift D after ten to fifteen seconds.
Apr 21, 2018 at 9:11 PM
PATENTED_REPAIR_PRO
  • 1,853 POSTS
Try a new filter and fluid change, perhaps the filter is a bit clogged with debris from the clutches.
Apr 22, 2018 at 12:37 AM
SHAHBAZ MALIK
Change filter and fluid but did not work.
Apr 22, 2018 at 5:45 AM
  • 55,770 POSTS
These cars had problems with the input shaft speed sensor for the transmission. Here is a video to show you what you are in for when doing the job:
https://youtu.be/f3bETtCIdxM
Here is the location for your car.
Check out the diagrams (below).
Cheers, Ken
Apr 22, 2018 at 5:47 AM
PATENTED_REPAIR_PRO
  • 1,853 POSTS
Was there a lot of debris in the pan that fell off clutch packs, etc?
Apr 22, 2018 at 6:53 AM
