Gear Problem
200,000 MILES • 2.4L • 4 CYL • 4WD • AUTOMATIC
BAJUS
  • 5 POSTS
after driving up to 50 km or when the engine is high in the gear when it is time to shift from gear two to three it will rev and accelerate without moving.
May 14, 2016 at 3:45 AM
  • 55,710 POSTS
Hye BAJUS,
This sounds like it could be one of three problems, first I would check the transmission fluid level, next it could be the turbine speed sensor that needs to be replaced. check you this video to give you an idea on what you are in for
https://youtu.be/f3bETtCIdxM
Next is not to fun but the transmission itself could need rebuilding.
Let me know what you find,
Best, Ken
May 17, 2016 at 3:18 AM
