Gear oil capacity
2013 RENAULT
422 MILES • 2.0L • 4 CYL • 2WD • AUTOMATIC
IFORIB91
I have a Renault Duster, 2.0 V automatic gear transmission, model 2013. Kindly, could you advice regarding the gear oil capacity of this car as I am planning to change its gear oil for maintenance.
Best regards,
Mar 28, 2016 at 4:40 AM
  • 55,673 POSTS
Hello IFORIB91,
Information on this car is difficult to find, but from experience 3 liters should be enough.
Apr 4, 2016 at 7:46 AM
ABADI
what will happen if bot an engine oil or transmission oil in a hydraulic pump?
Dec 9, 2019 at 12:54 PM (Merged)
HMAC300
  • 48,601 POSTS
if i get this right you are asking if yo put engine oil or tans fluid in a hydraulic pump what happens? nothing it will still work but maybe just not as well. i would change it out unless you put a small amount in it.
