Gear oil
150,090 MILES • V6 • 4WD • AUTOMATIC
BINA12313
Wen doing a fluid change in rear differential do I need to add a additive to it when it's changed?
Oct 24, 2018 at 1:11 PM
Good morning
No, all the additives necessary are already in the fluid you are adding to the differential.
Type
Front .................... Motorcraft SAE 80W 90 Thermally Stable 4X4 Axle lubricant
Rear .................... Motorcraft SAE 75W-140 Synthetic Rear Axle Lubricant
Capacities
Capacity
Front .................... 1.54L (2.7 pints) 9.56 mm (0.38 in)
.................... below the bottom of the filler hole
Rear .................... 2.60L (5.5 pints) (6-14 mm (1/4-9/16 in)
Oct 24, 2018 at 8:43 PM
