When the gear is put into drive, it did not select other gear.
3,000 MILES • MANUAL
MONEHIN
May 14, 2020 at 6:23 AM
Sounds like the shift cable is out of adjustment. You selected a manual transmission but I figured you meant it was an automatic.
I attached the process on how to adjust the cable or to just replace it if you can't adjust it any more.
Let me know if you have questions. Thanks
May 21, 2021 at 8:01 AM
