Gear Lever
2005 VOLVO XC70
102,166 MILES • 2.5L • 4 CYL • AWD • MANUAL
ANDYNICOJACK
The manual gear lever is able to select gears as normal. Car then drives as normal.
However the gear lever is very wobbly in all positions,
I remember forcing it into reverse recently due to stiffness, have I broken something?
Feb 25, 2016 at 7:48 AM
  • 55,433 POSTS
Yes, at the end of the gear shift is a round ball, on this round ball there is a plastic cover, it sounds like this cover has broken off which causes to play to be excessive. Please remove the gear shifter to inspect.
Mar 3, 2016 at 12:40 AM
